cmcclive
06.17.2009, 03:02 PM
probably depends on the ESC, if the ESC can't handle the 1000W then the ESC would fail before the batteries. Additionally if you have a capcitor it should lesses the peak draw from the packs a little...
But a better answer is probably on its way from BrianG or one of the other electronics people.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.17.2009, 03:10 PM
You gotta tell us more information about the setup you plan to use it in. But, just judging by the battery/motor combination, you might want to get a battery that can handle more continuous watts, maybe around 600 - 800watts... just to be safe.
