nitrostarter
nitrostarter's Avatar
06.18.2009, 10:53 AM
You got paranoid about your purchase...
N. Rustler conversion
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.19.2009, 07:33 PM
No I'm not...
Does anyone have any information on the cells used in these G3 packs? Are they from China? $100 for 3s 4200mah seems like cheap to me, but maybe they just came up with a good manufacturing process/chemistry that is lower overhead cost than previous gen. lipos.
I am reading on RCGroups, and helifreak that they really do live up to their claim (and obviously I have showed that, at least the 35C aspect), someone did some cycle tests and showed very minimal capacity or performance degradation after something like 60+ cycles.
zeropointbug
Z-Pinch racer
06.19.2009, 11:46 PM
I have been charging the packs on my switching programmable power supply(as my 720i has not shown up yet) at 10 amps (2.4C), I have put roughly 6 part cycles (~80% DOD) through them now and I decided I should check each cell voltage, I don't have a balancer, so I used some small wires and set the power supplies current to 10mA... this by far more accurate than my multimeter. After sitting for a day being charged to 4.133v/cell, each cells voltage was 4.11volts, all the same, when not even being balance charged. I guess Hyperion's matching technique is quite good, IMO.
BTW, these packs seem to have a flat discharge curve somewhat like an A123, but not quite as you have about a 1-2 minute drop when at 100% SOC.
