What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
06.25.2009, 04:55 PM
Originally Posted by Thomas View Post
I haven't done any soldering to A123 cells. A German distributor is stating "direct soldering will damage the cells".
Not true. You do need to use a minimum 60W iron with a heavy tip on it to hold lots of heat because that allows for a very fast joint. The cells don't get hot using this method. If you try to use a plain tip iron, or a low wattage iron then you will have to hold it to the cell longer and it may overheat and be damaged.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.25.2009, 05:53 PM
I have direct soldered all my packs with no performance or perceivable cycle life decrease. I use a 300watt iron to solder them.
