gimpygolden
gimpygolden's Avatar
07.05.2009, 07:27 PM
I tried that,as that is what I use on the al tabs on enerland cells. No chance of me getting the cell hot enough to melt that zinc solder.
I have successfully made 2 of the 5 cell a123 packs now... And am working on the rest. The neg side is not giving me much issue, it is the pos side. The guy in the vid must have a 10000 watt iron to do it that fast. I can barely get the end of the cell warm enough to melt solder... and I do not want to heat the entire cell to liquid hot...
I doubt the packs in the vid could hold up to a screwdriver prying the tabs up, that is my test when I make packs with bars.
The large tip is what really helps to as it "stores" more heat energy
"If yer not 1st,yer last"
OFNA GTP w/Quark-Medusa 60mm-5s
Inferno SP2 w/MMM-1512 2.5d-5S
Inferno St-rr w/MMM-1515 1y-5s
07.05.2009, 07:32 PM
Guess I'll be ordering some shrink wrap and balance taps! I was hoping to send my pack this week. I guess all good things must come to an end. Linc has done good work for me and many others and I thank him.
Linc - just cause some batteries are pissing you off is no reason to give up on RC all together! Go get a truck and drive it, drive the hell out of it, always makes me feel better.
I watched a few shamwow parody vids AND FEEL MUCH BETTER.
I have 180 watt iron that has a 3/16" wide tip that is hot enough to push thru a hooker, ask how I know that....
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
07.05.2009, 07:39 PM
No offense but if your such an expert then why aren't you doing this yourself rather than tormenting James with the task?
gimpygolden
07.05.2009, 07:44 PM
cause I'm a quadriplegic and don't feel like shorting out 30+volts (original plan was 10s)trying to get things together. I do all my own Ni-xx cells but was scared of these.
Good enough reason smartass.
