whitrzac
Can't catch this...
whitrzac's Avatar
07.09.2009, 05:20 PM
So are those two metal gears you put in the gears that strip? Which one in particular?
the lower plastic one that drives the diff, it striped out the pin...
I didn't have the right pinions, but if you find one the size of the top gear in the 1 speed(15t??), it will be alot stronger...
you cant use a modified 1 speed lower because it moves the pinion too close to the diff when you flip it...
