01.03.2006, 11:04 PM
and one more. sorry for the quality but they are from a cell phone. Will have good pictures soon
01.04.2006, 12:45 PM
I put silver on the front and blue on the back, I like the springs but my 60 in front and 50 in back need to to go like 75 in front and 65 in rear, or 80-70, I bottomed out too much, but was not bouncy
01.04.2006, 05:54 PM
Aren't those the LT springs?
The nose heavy problem i have may not be. the jump on my track that I was getting the problem with is profiled different from one side to the other, I tryed it from a different side and it flew perfect. I just need more power to find more problems. Thanks for the advise and i will try everything mentioned
01.04.2006, 06:16 PM
I am still bottoming out, with the LT springs, do they have heavier sets?
01.04.2006, 06:30 PM
yes. look in your owners manuel and it tells you the spring rate of all the springs.
01.04.2006, 08:43 PM
Heres the spring chart :
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
Site Owner
01.04.2006, 09:18 PM
It is perfectly OK to bottom out. That is why they call the bottom "skid plates" :)
In fact, the perfect track setup will usually bottom on the the biggest jump, but soak up the rest. If you set it up to not bottom out on the big jumps, it will usually handle the light stuff much worse(too stiff). If you are just jumping, then add 100 weight oil and some stiff springs and have at it.
Crazy - I don't find the g2R front heavy at all, really. Mine flies straight and true. The turning is impressive for the long wheelbase, too. I just got the rear setback arms(Traxxas part) in today, so I will mount these up and see what happens). I will get them listed in the store, too.
01.04.2006, 10:39 PM
Thats what i mean, I tryed a different spot and it flew prefect so i have a jump problem not a noseheavy problem. As far as turning, I agree, I was running at the track today and had spectaters some were Nitro Revo owners and they said it turned better than theirs. hopefully saturday I'll be able to compare heads up with a revo. I can't run speed for speed, but i can compare handling
One more thing Mike. which motor would prefer for racing with 4s lipo's? : A 1940/8 or 9 turn, a 8XL or 9XL wanderer or maybe an option i haven't thought of that you may know.
The rest of the setup will be a 9920 or 12020 warrior and a set of scorpion 6400 lipo's races could be anywhere between 5 minutes to 30 to 45 minutes. thanks for any advice you can give me
01.05.2006, 09:19 PM
you plan on getting more than one set of scorpions? dont think you could make 45 minutes with those packs.
Site Owner
01.05.2006, 11:16 PM
I actually have a 1940/7 motor that is about perfect for 4s Lipo. The 1940/6 is also a great choice. The 8 turn needs a tall gearing, but this was my favorite for 5s Lipo. I think the 7 turn 1940 is my all around favorite, followed by the 8 turn.
01.08.2006, 05:04 PM
just to let yall know, I have tried the LT springs and upto 80 weight silicon, I think my 14 gp3300 is too much weight. so I am going to get the P3 rockers to see if I can curve the bottoming out, sux cause I have to get the rockers and push rods
01.08.2006, 05:40 PM
In my g2r , i am using blue springs up front, silver in rear, with 80wt oil and it seems ok, your still bottoming out? I too, am gonna run 14 cell gp3300's , you have me worried that i might need somthing stiffer! :W:
Losi 8ight e
01.08.2006, 08:13 PM
I got silver in front and blue in back yeah I am definantly going to spring 4 p3 rockers and push rods
01.08.2006, 08:27 PM
Tell me how it goes, i might have to get p3 rockers too!
Losi 8ight e
01.08.2006, 08:47 PM
don't try the p3 rockers without the proper rods, I tryed it and the suspension is too soft and too low
Sylvester. you need to switch the springs around. I have the blue in the rear and the silver in front and it is awsome. Much betterin stability and cornering. you need the stiffer springs in back.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
