pinkpanda3310
pinkpanda3310's Avatar
07.22.2009, 10:06 PM
I rate these motors in this order- neu, tekin, castle neu, medusa
Neu- cause of it's temps but you may like to block the holes
tekin- cause it has a range of kv and blocked holes
castle- neu cause it's price to performance is great and has blocked holes
medusa- same as last except the holes are open
I have a neu 1515 1y on 6s2p a123's and a medusa 80mm 1600kv blocked holes on both and a heatsink on the medusa. Both have similar temps but the kv difference means I run the neu with higher top speed. But geared right the medusa is not far behind.
