Foxracin
07.23.2009, 02:37 PM
I am also a fan of clean wiring. Ijsut through this stuff on here to see what it will do. Its not how its goign to stay forever. Its my buddies Mamba Max I still ahve to find on for myself. There aint a whole lot of room to hide the wiring on these little things though.
Ill clean it all up and make it look better whenever I get me a new Mamba Max.
Anywho here is my Losi 8 it has pretty clean wiring. Only wires you see on it are the motor and battery wires. Still has the switch and everything on it.
Foxracin
07.23.2009, 02:41 PM
Also jsut went out and ran a 2 cell 8000mah pack through it and its barely got warm. Motor was at 132 and esc was at 110 or so at the lipo cutoff.
With a 2 cell it still runs great and is still pretty quick. Sill stand up no problem from a stop.
I still need to go a 1 or 2 teeth down on the pinion for the 3 cell.
nitrostarter
nitrostarter's Avatar
07.23.2009, 02:42 PM
If I'm not mistaken, that looks like an XL can motor, which explains the power and cool temps!
Looks good with the 1/8th scale tires and all tho!
N. Rustler conversion
Foxracin
07.23.2009, 02:58 PM
And your old Lipos.lol They have been working great man.
nitrostarter
07.23.2009, 03:25 PM
Thats good to know! Glad you like them!
07.23.2009, 11:24 PM
I criticize everyone a lot, incase you haven't noticed. Your wiring could have been much better. Motor wires could have been shortened 1" or so and you could have turned your battery around, so that you can drastically shorten those wires.
eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
07.25.2009, 10:47 AM
since you have it running, its time to throw the castle neu motor in there! it should fit just fine, and mabye if you can jam the MMM in there too instead of pinning the wing to the ground, standing and rolling backflips!
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
Foxracin
08.24.2009, 01:36 PM
Just changed the diff fluid in the center and there wasnt squat in there to begin with. Can you say standing backflips now? Standing backflip to backflip. lol
Still need to get some vid but its hard to drive and take a vid at the same time.
david lamontagn
08.24.2009, 11:41 PM
what diff fluid have you put in your's???
I have 20K up front, 50K center and 10K rear.
Foxracin
08.25.2009, 09:48 AM
Havent changed the front or rear yet but I put 50k in the center. It acts like a totally different beast now that you can get the power to the ground. backflips at nothing and even rolling backflips. Its awesome.
david lamontagn
08.25.2009, 10:14 AM
Yep! 50K in center diff of this little truck act like a locked diff
I have the same diffs setup in my brushless crt.5 and in my nitro crt.5 with an RB concept V-15 engine, and it's a realy beast too, i realy like both truck, nitro and electric
