Over_revO
07.24.2009, 06:13 AM
Ok thx for the info on the cell,
It do run when setup on automatic 78% , but will hit the cut-off, but running just one 4S is fine, no matter wich one i use...
Is there an easy way to test the amp on the cells?
we tested to reverse the wire, controller, nothing worked :(
thx
a6m532
07.24.2009, 09:59 AM
Hi,
You should be able to read the max current from the software use to set the parameter of the controller. b2 setting should be set to zero.
