1/8 buggy mamba max esc overheat ?
Rating:
littlegiant
07.31.2009, 02:42 PM
Is the Neu a 4 pole motor? If it is, use 15 timing.
It doesn't sound right that your mmm will overheat with your setup.
How heavy is your setup?
littlegiant
Find all posts by littlegiant
2
littlegiant
07.31.2009, 03:13 PM
Originally Posted by
littlegiant
Ok my mistake. I tot you were talking about a MMM.
littlegiant
3
Jason
07.31.2009, 03:49 PM
the stock diff ratio is 2.8 how about if I put my kyosho diff the new ratio is going to be 4.3 .. ?
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 50
Pinion Tooth Count: 13
Total Voltage: 14.8
Motor KV: 2700
Tire Diameter (inches): 4.3
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0082
Spur/Pinion Ratio: 3.85 : 1
Total Ratio: 16.53846 : 1
Tire Circumference (inches): 13.51 inches (343.12 mm)
Total Motor Speed: 39960 RPM
Vehicle Speed: 30.91 mph (49.65 km/h)
Effective KV Value: 2700
KT constant: 0.5 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
Jason
Find all posts by Jason
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
