Is this sound normal? VIDEO
simplechamp
simplechamp's Avatar
Is this sound normal? VIDEO - 08.04.2009, 05:44 PM
I just got my E-revo today. It's in good shape, but it seems loud when I roll it. The gear mesh seems correct, has a tiny bit of play like it's supposed to. Never heard the gears so loud on my other vehicles. I can definitely feel the magnet resist rolling, which I expected for a heavy duty brushless, but not the noise.
Watch the vid if you wouldn't mind and let me know what you think. Am I just being a noob? Or is there something that should be looked at?
bruce750i
bruce750i's Avatar
08.04.2009, 05:51 PM
Sounds good to me.
wallot
wallot's Avatar
08.04.2009, 05:58 PM
remove pinion and roll it. it should be quiet. with pinion it is quite normal
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
simplechamp
08.04.2009, 06:18 PM
I slid the motor over so that the car is free-rolling. There is still some noise coming from the transmission.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.04.2009, 06:36 PM
Yes, that is quite normal... different size pinions will give different sounds, and some will be quiet.
simplechamp
08.04.2009, 06:45 PM
Did you watch the second vid? The second one has the motor moved away from the spur, it's now free-rolling but still making noise.
scarletboa
scarletboa's Avatar
08.04.2009, 08:00 PM
my t-maxx does the same thing. it makes the sound most if i brake hard.
Andrew32
08.04.2009, 08:20 PM
hmmm. something may be in your transmission or driveline...
junkman
08.04.2009, 08:24 PM
I'd say sounds normal. They are just noisy rigs for some reason.
simplechamp
08.04.2009, 08:36 PM
Really? I can understand the sounds with the first video when the pinion and spur are meshed, but the second video is has the car completely free rolling with no pinion/motor engagement and there is still intermittent grinding/binding.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.04.2009, 09:05 PM
Jason,
If It's not binding or tight NO WORRYS. With all the gears and drive train parts it's gonna make noise.It's Normal. Fire it up and drive it like you stole it and have fun.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
08.04.2009, 09:49 PM
The first vid sounds normal. The second vid sounds like the diff pinions are too tight or something.
simplechamp
08.04.2009, 10:17 PM
Well I tore it down to try and find the issue. Trans is all good. What's_nitro hit it on the head, there is some binding going on with the diff pinions. When the diff case is loose it doesn't bind, but when you tighten all the screws it starts binding again.
Either way, I'm going to be installing the V3 hybrids this weekend and the alum. diff cases wont flex or warp like plastic, plus I can shim better with the 1/8 diffs. Should solve the issue. Just needed to make sure there the transmission gears weren't beat.
So yeah it sucks that I get my first monster truck and can't drive it for a week, but I got the V3's, full CVDs on the way, and when it's ready to run the drivetrain will be solid.
What's_nitro?
08.04.2009, 10:21 PM
I had the same problem with my Ofna GTP. I'm sure it would be OK to drive with the screws a bit loose of you wanted to. If the screws are going into plastic then they shouldn't have loads of torque on them anyways.
junkman
08.04.2009, 10:29 PM
pretty much every revo/maxx diff I have messed with does not mesh well. I have a new pair right here that I just bought for a project. The are very tight and notchy feeling. I am sure if you spent some time on them you could get the much better. If you going to change the setup anyway and you just got the truck I say stick it back together and go have fun. If they mess up on you you were going to do something different anyway. I'd say that how 95% of the revos running around are.
