nieles
nieles's Avatar
08.15.2009, 05:08 PM
i use an turnigy servo tester for throttle on my e-scooter
http://www.hobbycity.com/hobbycity/stor ... oduct=6554
and i modded it with the insturctions from a guy at endless-sphere to use it with standard bike throttles
http://endless-sphere.com/forums/vie...php?f=2&t=9413
  Send a message via MSN to nieles
Metallover
RC-Monster Spudgunner
Metallover's Avatar
08.15.2009, 05:35 PM
I see. I think it's just my servo tester uses a 20k pot and I need a 5k pot. I'll look into getting that servo tester my next order from hobbycity. Thanks!
brushlessboy16
brushlessboy16's Avatar
08.15.2009, 07:47 PM
With the incorrect pot you will get 1 of 2 things
a. you will never get full travel to the tester
b. the signal that the tester sees will be very narrow
like full lock one way will be 1/16th of an inch.
you need the correct one for it to work correctly
Kyosho
08.15.2009, 10:10 PM
Whats your run times? or have you really tested it yet. im thinkg about doing a mini bike or pocket bike instead. and i have seen a pocket bike that looks exactly like yours and its allready electric. but is this the one you have? the motor mount on the one i saw looks like yours.
Metallover
Metallover's Avatar
08.15.2009, 11:26 PM
Well, it depends on how much capacity the batteries still have left in em. An estimate is 36wh/mi for this type of motor. If I was running 36v, my theoretical range would be 10mi. I don't think I'll come close though, with my leads and 24. Maybe 3-6 miles.
scarletboa
scarletboa's Avatar
Talking 08.15.2009, 11:29 PM
you should get a couple 6s 5000mah 20c turnigy lipos. they are $60 each and they should be more than enough for your setup........unless fat bastard (from Austin Powers) wants to take that bike for a spin.
Metallover
Metallover's Avatar
08.15.2009, 11:40 PM
Lipos are on my list. My list that is a "whenever I feel like upgrading this thing" list. I'll probably get 4 so in the future I can run 12s2p setups on bigger outrunners and bigger bikes..
But 2 might be enough for now.. Unless like you said, fat bastard tries to ride this thing. It'll need some serious power then!!
Kyosho
08.16.2009, 11:20 PM
I am gonna buy a pocket bike some time this week. i might go with a system form monster scooters or whatever. is your bike origonaly the 50cc gas version or was it allready electric? i saw one that looks identical to yours and was allready electric.
Metallover
Metallover's Avatar
08.17.2009, 07:41 AM
This one was already electric. It had a full 180 watts. Now it has a motor rated for 2400 watts.
Kyosho
08.17.2009, 10:52 AM
I dont want to copy you a whole lot but i think i might get the allready electric one. then i dont hve to make a new motor mount.
Metallover
Metallover's Avatar
08.17.2009, 11:12 AM
You'll probably still have to make a mount. Some motors are mounted with the front but most likely they'll be mounted by a plate welded to the bottom of the can of the motor.
Kyosho
08.17.2009, 11:16 AM
oh ok, but its still alot cheaper than most, but i did find locally a gas one that is only a year old, he ran it a couple times but then he broke the pull start, selling for $60 canadian! the electric ones are around $70 used. Mabey i will just get the gasser.
Metallover
Metallover's Avatar
08.18.2009, 04:23 PM
****Performance Report****
I measured out a 1 mile loop. The terraing is extremely smooth asphault. It's ideal conditions minus a little wind. With the 10ah 24v sla pack, I got 5.5 good miles out of it and it died at 5.75 miles. I was able to limp back and finish the 6th mile. Average speed was about 10mph and avaerage mile times were about 5:30-6:00. Temps were about 105 controller, 90 motor, and the batteries were ambient. I don't know what top speed is, but on a fully charged pack it's probably 20-25mph. It seems like it's haulin when you're riding it.
I had a more detailed, much longer post made up but I lost it all when my browser crashed.
Here's the video. It's after 4 miles, so most of the top end is gone. I edited the video my way.
Photobucket blocked my video with copywrite, and I'm sure youtube would, so here ya go on imageshack.
[Upload your own video]
Here is the test route
And here is my town. With a 5.5mi range, look at all the places I can go!
Kyosho
08.18.2009, 07:09 PM
Awsome! I might be picking up my bike tomorow. Do you think this kit would be good?
http://www.monsterscooterparts.com/2...ottle-kit.html
Metallover
Metallover's Avatar
08.18.2009, 07:16 PM
If it mounts right up, why not? My system is probably 1300-1500w, so keep that in mind. I wouldn't expect speeds over 20mph with that though. Maybe 15-18mph. I would try to find a higher power system or use an rc system like I did.
My motor cost $55 and my controller cost under $30. A servo tester costs $5-10 and a pinion is cheap at mcmaster carr; probably $2.50.
