Batfish
Batfish's Avatar
01.14.2006, 10:06 AM
Originally posted by JOHNNYMAXXIMA
Does anyone know if FMA will custom make a Scorpion pack for you?
I like the idea of those "monster truck" packs, but would like to get a little more voltage to my 9L than the 14.8v of those monster truck packs.
For example, would I be able to run one 5s pack (one pack per speed controler for my dual setup?) I would particularly like a setup like that for my dual 9L Maxx because I am currently using 4 chargers to charge the 4 7cell Nimh packs that are in it now. And if I would be able to run two 5s packs(1 per motor/controler), that would eliminate 2 extra scorpion chargers that I would have to buy.
The 9L can handle up to 19.2v (16cells) can it not?
Please let me know how far out of wack my thinking is.:o or if it even made sense.
Thanks.
For what you're asking, FMA makes the BalancePro HD lipo line now.
http://www.fmadirect.com/new_applica...shPG/index.htm
You can buy a single pack from 2s1p 7.4V 3200mah up to 6s3p 22.2V and 9600mah, with all of the benefits of the Scorpion system - up to 3C charge, 20C discharge, balancing, low-voltage cut-off.
They also say this in regards to BalancePro HD
"Additionally, custom BalancePro HD packs can be
configured to fit your individual needs.
Please contact our Technical Support team for
that special pack you have in mind."
The Scorpion packs are for the people who want "normal" voltage :)
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
