Gary NJ
08.07.2009, 11:42 PM
Originally Posted by Jarvis View Post
Did you have to mod anything to make them fit?
No mods at all when you use them on the rear. For the front, you have to Dremel just a hair off the universal right at the point that it passes over the lower outer hingepin. If you don't grind a little, you'll see a mark on the universals at that point in a few tanks. I had one universal bend when it got hung up at that point when I didn't grind it once. I mostly run the 8.5s unisnow because I had a lot of them from when I ran the 8.5 car.
