Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
08.14.2009, 08:27 AM
Indeed, 99% of PC cooling fansd like this are BL- the white/yellow wire is the signal wire, so that when plugged into a fan controller or the PC's motherboard, the speed can be controlled to increase cooling when needed, or to decrease cooling & noise when not needed. The actual controller is built into the fan, you just vary the volts the vary the speed.
KaztheMinotaur
KaztheMinotaur's Avatar
08.15.2009, 04:36 AM
I got my gear cooked today and they are no longer nice and shiny. I'm soaking them in degreaser to the gunk off. A minute or 2 with a wire wheel and I am starting to see silver again. Burned boiling oil smells horrible.
Ryu James
Ryu James's Avatar
08.17.2009, 02:59 PM
did you do it yourself or somewhere else do it for you? exactly how was it done, do you know?
Jammin SCRT10 Neu 1512 1y
KaztheMinotaur
08.17.2009, 03:36 PM
I bent a hook on the end of a straightened coat hanger and hung the gear on it. My mechanic heated it up with the torch to cherry and I dropped it into the oil.
Ryu James
Ryu James's Avatar
08.17.2009, 04:12 PM
just used motor oil? or new? 10w30? lol.
KaztheMinotaur
08.17.2009, 04:41 PM
It was a misture of new Wal-Mart brand 10-30 and Valvoline 10-30. Thats what I had laying around.
KaztheMinotaur
08.18.2009, 12:09 PM
I had to do some dremel sanding to get the hub to fit into the milled out area after the hardening? Wonder if the gear would have changed size slightly ? Or maybe it was a buildup of oil bakes on gunk ?
