aqwut
Brushless Heavy Weight....
aqwut's Avatar
08.17.2009, 11:08 AM
Yeah, Finnster.. I played with all of that for more than a few hours... I've tried everything except plugging the cable in the other way...
Problem is, it doesn't beep at all... THe UBEC works fine though... It doesn't take programming from the Tx and/or USBCom++ I haven't even used this ESC yet, as it never worked.... but I keep trying because the BEC Works on it...I took the shrink wrap off and tested all the wires and solder joints.. everything was fine... I'm really stumped with this thing... I've tried everything that I could think of...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
lutach
lutach's Avatar
08.17.2009, 11:46 AM
Have you tried running it OPTO and using a Rx pack or a External BEC?
aqwut
aqwut's Avatar
08.17.2009, 12:25 PM
Yeah Lutach, I've tried opto...
Hey Finn.. I let the thing sit on the laptop and took off for a while... I came back, turned the switch on and it read the data.... I am able to access the ESC now.. but still unable to get any beeps or respons from Transmitter... I've tried a few transmitters... still no results... but the funny thing is, when I looked at the Controller program... it shows..
Maximal current Peak [A]: 94.72
Current in full throttle [A]: ------
Voltage of battery at switch off [V]: 14.912
Max. Temperature [C]: 306.43
the voltage and Temp looks very funny to me... Even when using a 6S battery to program it doesn't change.... I don't understand that 306.43 Degrees Celcius data?... what are you guys getting?... Haven't even use this thing yet..
