Semi Pro
Semi Pro's Avatar
08.18.2009, 03:07 PM
Wowsers, for 90.00 + tax for 2 sets they dam well better be bullet proof.
Wonder if these could work in a Lightning Stadium Pro diff set up ????
the spiral cut diff gears in your lsp are bullet proof if you shim them right i have been useing them for years with no failures
there is no such thing as bullet proof gears, they all will ware down and need shimming or they will fail
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.18.2009, 04:13 PM
LOL ?
I never have problems with wear, Gone thru many bearings though !
I have problems eating gears when I brake the outside diff case under extreme jumps. I was thinking the straight cut gears would hold up better after the case breaks. The spiral cut gears always get the tore up on the ends.
Semi Pro
Semi Pro's Avatar
08.18.2009, 11:11 PM
LOL ?
how often do you servise your bearings?
i went to wala wala cermaics after i had a stock bearing fail and since then i havent ever had a diff fail, mine is used for bashing too
sikeston34m
sikeston34m's Avatar
08.18.2009, 11:22 PM
I wonder if these will fit the Hotbodies diff center........that the RCM case takes?
Hmmm..........
