Jesse M
Jesse M's Avatar
08.22.2009, 11:44 AM
Riverat, are you saying it 'woke up' after switching from a 62 to 46T spur gear or just the brushless conversion in general?
Couple other questions-
Why did you switch to the smaller spur gear?
Is there a benefit with the Kyosho gear over Ofna/Jammin 48T spur gears like wider teeth or something?
riverat1540
riverat1540's Avatar
08.22.2009, 07:02 PM
yea it seemed geared way better for the track after small gear conversion, i believe the kyosho gear is plastic which is why many opt for it for quiet running and longer pinion life. there is some shimming involved to make the hot bodies pinion work and u also have to extend the flat spot a few milimeters. but its worth doing and gives u more gear options. i run the hotbodies ring and pinion set and a 46cr gear and a 14tpinion and find it great at the track. just dont swap the spurs without doing the ring and pinions as i ran it a week that way and ended up snapping my motor shaft. but yes i noticed more bottom end and responce after the ring and pinion conversion
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
