lutach
lutach's Avatar
08.30.2009, 02:40 PM
Originally Posted by florianz View Post
the other's guy esc burned, when the car rolled backwards and then wanted to go forwards, heavy cogging, then smoked. he says that this cogging can kill an esc.
My Schulze burned up when my truggy rolled backwards and when I applied a small amount of throttle to go forward (No cogging though). If the ESC cogs (Stutters), it's basically telling you it doesn't know where the rotor is and that can cause huge AMP spikes. If the ESC cogs a lot, you must stop immediately or risk loosing it or something else. It might just be a software issue due to the lack of testing or the ESC might just be made for 2 pole slotless motors.
florianz
08.30.2009, 02:59 PM
I think I will remove reverse, to be on the safe side.
overall there is no cogging, and most times startup is very smooth. but the hard cogging (not that often) just does not feel healthy...
I definately can say that my modded plane esc's had less or no cogging, so thats new to me.
littlegiant
08.30.2009, 03:24 PM
OK now that I know this, i feel worried about my MM and HW150A. So are sensored esc with sensored motors safe from this problem?
Will smaller pinions help prevent sensorless escs from burning up when a truck is rolling backwards and u give it a little throttle?
lutach
lutach's Avatar
08.30.2009, 07:47 PM
Speed controls are made different. Some will have a different firing sequence. Sensored ESC should not have an issue locating the rotor. A smaller pinion will lessen the load on the motor, but anything can cause a ESC (Or motor) to fail. If you have a ESC that offers a setting to completely brake before going forward, this should not be a problem and I know the Castle car controllers has this options.
florianz
09.04.2009, 04:33 AM
hey lutach,
do you have a manual of that esc? I have NO clue how to change the settings, and they shipped the esc w. the wrong manual... the lipo-cupoff is pretty low, so it almost killed my batteries the other day.
a couple of times the esc was "off" suddenly, maybe it's a problem of the receiver, dunno yet. together with the new 12v fan attached to the batteries, the temps were around 35-40 deg. c after 3 batteries. the rest was ok, too.
thanks a lot,
florian
lutach
lutach's Avatar
09.04.2009, 09:20 AM
hey lutach,
thanks a lot,
florian
I don't, I haven't spoken with the manufacturer for a while now. My last e-mail to them was on 12/04/08. Did they send you the program card? They told me that every ESC was going to come with one.
florianz
09.04.2009, 10:11 AM
the one esc sold by "Graupner", the Genius 120r, is sold with a card, and therefore costs a bit more then the one sold by "Jamara", the Flash 3000, which is sold w/out card. in some shops you can get the flash for about usd 120,- . the single programming of card of jamara is not available yet.
lutach
lutach's Avatar
09.04.2009, 10:30 AM
Those guys are just making a profit on the cards. They come with it from the factory. I don't blame them though. Now if they had the option for PC programming then they could charge it as it's an option from many places that does it. Jamara doesn't have the manual online? Send Jamara or Graupner an e-mail asking for the manual.
