Thomas
Thomas's Avatar
09.02.2009, 03:45 PM
From a technical point of view, this chassis must have very little torsional stiffness. To change this, you need diagonal beams or plates (e.g. CF with bolts in all four corners) connecting the four main beams. Anyway, you've built a nice vehicle.
gyn77
09.02.2009, 04:33 PM
Today I have received front baja tires. I had choosen bowtie tires to have front grip because my baja is 4wd.
The baja now weights 7,6 kg in RTR conditions. This is the real weight mesured!
Testing the baja with original wheels in my home with the same pinion (14t) used before with smaller savage wheels, I don't see any cogging, mamba monster is great and smooth and neu 1521 is very powerfull, but I will use 12t pinion and get estimed max velocity of 95 km/h!
I remade the front cvd using an alluminum full tube instead of empty alluminum tube. Now it seems to be more strong but I have to try it to see if it is strong enough.
