Looking for a certain thread
brushlessboy16
brushlessboy16's Avatar
Looking for a certain thread - 09.02.2009, 09:52 PM
A while back there was a thread all about motor timing and esc settings for the different winds of motors....
If anyone has a link or something like it I could really use it :)
-Ben
09.02.2009, 09:58 PM
what motors were you most concerned about?
brushlessboy16
09.02.2009, 10:01 PM
1515 1y and 2d
running the 2d in a buggy, 4s lipo, geared 12/48 and its temping at 160.. cant get it to cool off.
09.02.2009, 10:10 PM
From Neu's web site using castle controllers, ...D winds should use low timing, no benefit from higher timing...Y winds can use med. timing for more power but will not be as efficient
brushlessboy16
09.02.2009, 10:11 PM
Im running 0 timing on a 2d. and it wont go below 160 geared for 35
starscream
RC-Monster TQ
starscream's Avatar
09.02.2009, 10:18 PM
1515 1y and 2d
As magman said, Delta winds work best at low timing
A 1/8th buggy on 4S and 2050kv motor should be geared around 16/46 with low timing
12/48 is very low gearing and most likely the reason you are seeing high motor temps.
Gear the buggy closer to 16/46 with low timing and you should see your motor temps come down.
Ha Ha
brushlessboy16
09.02.2009, 10:19 PM
i geared 16/48 and the motor was at 180 after a main...
so gear up with the lower 2d. leave timing alone?
starscream
RC-Monster TQ
starscream's Avatar
09.02.2009, 10:25 PM
NEU motors are OK up to 170F so 180F is bad
It sounds like the motor may be failing.
Are there any mechanical issues with the motor like worn bearings or bent shaft? What kind of shape is the motor in?
Ha Ha
brushlessboy16
09.02.2009, 10:27 PM
bearings are good to me, no play at all. no bent saft. motor looks fine visually.
09.02.2009, 10:32 PM
Any binding anywhere? My 1512 started to get hot just before the bearing failed...so that could be the issue
brushlessboy16
09.02.2009, 10:37 PM
car rolls fine , i have no idea what could be the issue
09.03.2009, 09:30 AM
As stated above...w/0 timing, try going up 2 teeth and retest and go from there. My 1512 go hot when I first tested...168..I went up 2 teeth and it never gets above 145 now.
brushlessboy16
09.03.2009, 10:15 AM
alright, i had a 16 on it, that temped at 180, 12 made it 160. sweet spot in between you think?
worth a shot
09.03.2009, 12:21 PM
Definately worth a shot....it took me a while to find the sweet spot w/my 1512. Even 160 seems a bit though though
nitrostarter
nitrostarter's Avatar
09.03.2009, 01:52 PM
Not enough load on the motor create inefficiency which we all know creates heat. This may be your case.
Also, throttle usage. Whether you are jerky on the throttle like the nitro guys. Or smooth on and off like a BL should be.
N. Rustler conversion
