Chris911
01.23.2006, 12:06 AM
Originally posted by boss 302
you would have to use a ubec on anything over 12 cells
I'm using 14 cells now but i assume you mean with the warrior?
Is the Maximizer worth getting or should i just get UE's diffs? If i get the Maximizer whats a good diff case to put them in? Whats the option of them for robinson gear mean?
I would also like to replace the stock Steering Block i guess this will do? but where do i find the rear ones?
Thanks!
boss 302
01.23.2006, 08:00 AM
correct
Chris911
01.23.2006, 11:56 AM
Will the Integy Super-Duty Type II Steering Block work with the Gorilla Maxx G3 Race Suspension? Also where is the Integy block for the rear??
squeeforever
squeeforever's Avatar
01.23.2006, 10:42 PM
the front and rear knuckles are the same.
Chris911
01.24.2006, 12:31 AM
So this will fit the front and rear?
http://www.rc-monster.com/proddetail...eringmx&cat=17
It says steering so i just thought they where for the front only.
coolhandcountry
coolhandcountry's Avatar
01.24.2006, 09:41 AM
That is the ones. Well if you mount a servo on the back it would steer to. I have this knuckles myself. They are nice. You need to loctite the stock pillow ball caps or get the plastic or one with the oring on them. Just to let you know. The 9l is nice if you not running to heavy maxx. The 8xl just has more torque like stated.
Peace!
Country
Help support the
Rc-Monster
Buy here
boss 302
01.24.2006, 07:23 PM
the torque an xl has allows for higher gear ratios so u can get more speed but the torque also makes it more critical to have a strong drivetrain
Chris911
01.25.2006, 12:32 AM
What would be a good Strong drivetrain?
boss 302
01.25.2006, 07:11 AM
ue 8 spider diffs
ue 6mm cvds
hardned steel idler gears
that would be a good start you could also get the gmaxx single speed conversion and flm bulkless
Serum
Serum's Avatar
01.28.2006, 04:13 AM
Moved from g-maxx to brushless
