09.08.2009, 03:34 PM
Originally Posted by MGM Article
a) Use batteries that have truly very small inner resistances (as e.g. Kokam 30C with a suitable capacity).
It is therefore not enough that the seller or distributor states „high Cs“ for the battery and that it can supply high
currents
!!! An example of such batteries are packs made of A123 cells, which can provide high currents without damaging
themselves, but the inner resistances are high. At the same time, it is necessary to make sure that conductors between the
battery and the controller are as short as possible and use quality connectors, that is no "4 mm golden plated banana plugs" or
"Dean" etc., but at least MP JET 3.5mm or better 5.5 or 6.0mm. Conductors with a cross-section of at least 4mm2 are also
essential (that is 11 gauge in US units) and quality soldering (our concern are not 1:18 models, but the bigger ones, of course).
Nevertheless, even batteries with very small resistance might not be enough – in some combinations with powerful motors and
bigger models, even with a very good battery, voltages higher than the controller can take can be generated.
b) Use controller for higher voltage than it seems to be needed from the point of voltage on the pins of the battery (that is for 6Lipols use controller suited for at least 8 Lipols).
c) Use „controlled shunt load“ for partial braking current stream diversion, additional module for controllers – under development.
d) Brake softly – this however is quite hard to achieve correctly in practice.
I love this. I don't know how many arguments I've seen at that "other place", but the above really drives home what many more technically inclined people have been saying.
It seems to me that point A is really talking about the Zippy vs any-other-battery debate. High C rates mean little. Resistance is what really matters.
Point B makes simple sense. We all know that brake voltages can be substantially higher than the battery, so if someone is using batteries to the max ESC spec, it's only natural things can go wrong during braking. This is exactly why I NEVER run max spec voltages on ANY ESC. And between you and I, think this is why some people have been blowing MMM ESCs. Gearing a relatively heavy vehicle for stupid speeds on 6s, and then braking fast makes me shudder. Just imagine the kinetic enerfy contained in a 10lb+ vehicle traveling at 60mph+ and trying to stop on a dime.
Point C is basically talking about using some kind of TVS device to shunt overvoltages to a safe level. The MMM uses this, but like any electronic device, it does have limits on what it can absorb. I was rather surprised to see such high braking currents though; I expected values around 20A. And since those current spikes are so short and so large, it makes sense that you don't see much runtime increase; the battery simply cannot charge that fast. Maybe someday we'll see battery charge rates in the 30C range, but certainly not today.
Point D. Well, that is just asking too much of users IMO. When I'm running full tilt and then a curb happens to "jump in the way", the last thing on my mind is whether the ESC will handle the voltage/current spike if I brake hard. It's just instinct (for me anyway) to jam on the brake.
