J57ltr
09.14.2009, 11:42 PM
That was just in case you wanted to charge both batteries at the same time or if you wanted to use the 18V battery.
Jeff
09.14.2009, 11:53 PM
I was thinking of charging them as a 12v 24ah setup. Would that work with my current PS?
J57ltr
09.15.2009, 12:15 AM
With what you have yes, the only thing you have to worry about is that the lower the voltage on the batteries the more current they are going to draw, so it might trip the PS when you first start to charge them. The only other thing you have to worry about is charging them too fast. I think a 12 Ah battery is recommended to be charge at about 2.5 amps max, but with them in parallel that would be 5 amps. If you have an adjustable power supply (most are) you can lower the voltage and watch the current drop and then slowly increase it until you are at the 14.4V value. I have been using a regular car charger the maintance free kind with a couple of resistors in series with the + output.
Or I will use my 60 amp power supply and just watch the gauges set it for about 1 amp charge and when the current drops I increase the voltage till I am back to 1 amp then repeat until I am at 14.4.
The maintance free charger is the easiest way since it will only go to 14.4V
You could get a 24V power supply and charge them in series and not have to remove the batteries and reconnect them.
Cheaper ones:
http://www.mpja.com/prodinfo.asp?number=16854+PS
http://www.mpja.com/prodinfo.asp?number=16855+PS
Jeff
