Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
whitrzac
Can't catch this...
whitrzac's Avatar
09.24.2009, 04:04 PM
Originally Posted by sabongi View Post
the shroud could be made of aluminum so heat would be dissipated better :(
that would cost$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $
09.24.2009, 04:15 PM
lol, it does look like a V engine... one with a HUGE crankcase.
emaxxnitro
emaxxnitro's Avatar
09.24.2009, 05:02 PM
same fan as the mmm. oh well it will work for a while at least
808E
Shark413
Shark413's Avatar
09.25.2009, 02:42 AM
I recieved a couple of them today and tried them out on various motors to see what they fit. One thing I noticed was it is basically a shroud and relies on the cans cooling fins for output venting. So smooth can motors may not vent as well, or I guess you could drill some holes, but I think the logic was to blow air around as much of the can as possible before venting.
Pictures:
Fits perfectly on a Neu-Castle
Fits on a finned Neu 1515 perfectly as well
And a finned Neu 1512 (same diameter)
Doesn't fit on a 1515 Tekno-Neu square can - Duh
Fits pretty good on a Tekin T8
Fits ok on a smooth can Neu 1509 (a little loose)
Worked ok on a Feigao
Too big for a Castle CMS36 can
Way too big for a 540 sized can
And the only output venting is via the ribs on the can.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
Brushless Moose
09.24.2009, 06:17 PM
As much of the motor as it covers up, I worry that it will only add to the heat problems.
brushlessboy16
brushlessboy16's Avatar
09.24.2009, 06:19 PM
Its flowing more a larger volume of air over that portion of the motor than if it were uncovered.... Soor to shoot down your logic
Brushless Moose
09.24.2009, 08:42 PM
I have one on order to cool y overheating tekin. Temp on the motor after a 15 min. main are over 185F
brushlessboy16
09.24.2009, 09:16 PM
yikes something isnt right.
Brushless Moose
09.24.2009, 10:01 PM
I know. Check out my thread in the tekin forum. I have checked EVERYTHING. It just runs hot!
big greg
09.25.2009, 04:46 AM
man that fan has been around already! what a "$@re lol
austinmaxx
09.25.2009, 04:13 PM
lol does it cool much ?
BashemSmashem
09.25.2009, 09:00 PM
So do these work or what ? Will they fit the TORK motor ?
simplechamp
simplechamp's Avatar
09.27.2009, 07:02 AM
I don't think so because the Tork has the heatsink in the center which will get in the way.
09.27.2009, 08:25 AM
Tork motor has much longer cooling 'pins' vs the shorter fins around the afforementioned motors, so you would have to stretch it so much that it might break/ split.
You could stick the motor in a lathe though I suppose....
BashemSmashem
09.27.2009, 09:01 AM
Actually IT DOES fit the Tork motor ! My son just got his and yes you do have too stretch it on kinda but it looks good and works GREAT ! Much cooler now than it was without , though we were only hitting the 140's before , but he wanted it for the cool factor . And I must say , it does look pretty cool !
