9920 brakes?
phildogg
phildogg's Avatar
9920 brakes? - 01.21.2006, 08:28 PM
I have a 9920/8s combo in a rustler, I have been running it for around 2 weeks or so and have little to no brakes.. I have reproggramed it a couple times to make sure but doesn't change anything.. It does have brakes but when trying to stop it gradually slows instead of trying to lock the tires like my other systems in st did. any ideas?lmk
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
squeeforever
squeeforever's Avatar
01.21.2006, 08:45 PM
could it be your radio?
phildogg
phildogg's Avatar
01.21.2006, 08:49 PM
what about the radio? I'm using the stock radio so it may be. I also have a futaba 3pm so will try that later stripped a diff yesterday so have the tranny apart..
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
coolhandcountry
coolhandcountry's Avatar
01.21.2006, 09:12 PM
The 9920 had a problem with some of the escs and this brake problem. Dafni on here had the same problem. It is like a brake fade.
Peace!
Country
Help support the
Rc-Monster
Buy here
phildogg
phildogg's Avatar
01.22.2006, 10:03 AM
I thought brake fade happened gradually? this controller has never had brakes.. If there are probs with the warriors then why recommend them all the time?
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.22.2006, 11:18 AM
There were a few warriors with the brake fade a year or so ago, but these were replaced under warranty. The warriors are great controllers for the $$. If your controller is faulty, then I am sure it will be replaced. The few that had issues all seemed to happen at a certain temperature(when the controller got to a certain temp, the brakes would disappear). The first thing I would try is radio adjustments. Make sure you transmitter isn't set on 70/30 throw for starters. Re-program it with the 50/50 setting if it was and go from there.
phildogg
phildogg's Avatar
01.22.2006, 01:37 PM
The controller is set at 50-50. anything else to look for?lmk
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
phildogg
phildogg's Avatar
01.23.2006, 04:42 PM
anyone?
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
Dafni
Dafni's Avatar
01.25.2006, 02:49 PM
If you have no brakes or only very weak brakes right from the start, and you're sure about your radio, then there's something wrong with your ESC. The warrior brakes will flip any truck if there's enough traction.
RC-Monster Mike
Site Owner
01.25.2006, 04:28 PM
It is quite possibly set in another mode besides car mode(would need a programming cable to change this). You can send it back my way and I will make sure it is AOK.
01.25.2006, 05:33 PM
What about the throttle trim pot?
phildogg
phildogg's Avatar
01.25.2006, 06:14 PM
I'm going to try my other radio and get back with ya. right now the diff is out broke a tooth.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
phildogg
phildogg's Avatar
01.27.2006, 06:36 PM
changed out the stock radio to my 3pm and has brakes now. don't know why it didn't with the stock radio.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
Serum
Serum's Avatar
01.27.2006, 07:32 PM
Okay, so this 'If there are probs with the warriors then why recommend them all the time?' can be ignored? ;)
Cool that it's fixed though!
Just try your stock radio and plug a servo in channel two, and see if it has the same turn to both sides.
Batfish
Batfish's Avatar
01.27.2006, 08:25 PM
I want to echo what Serum said here. I was one of those with the "brake fade" issue with a BK Warrior 9918 last year. I think there were 3 of us. Consider this: there were at least 100 others that were sold and did NOT experience any problem. The BK Warrior controllers have gained a reputation as very durable and most people are actually shocked when they hear about one with a problem. That is why folks here initially asked you to check everything else :)
Glad it works for you now!
Remember that Mike is just an email away if you have questions.
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
