Nixpus
09.20.2009, 05:48 AM
Yep in order to get the same amount of power (watt) Id have to increase the voltage on a low KV motor, since it have more windings/turns and thus draws less amps.
This also ansvers my question. With the same voltage available the low KV motor should be easier to handle - if geared for the same top speed - since it will have a lower power output. Cheers... KB45-10/11XL here I come :)
