BL Revo using Revo Transmission?
BL Revo using Revo Transmission? - 01.22.2006, 12:37 AM
Just wondering if there was a good BL motor to use with a Revo using a stock transmission with a 40T, standard pitch spur? I'd think the gear ratio would be quite a bit less than using an E-Maxx tranny and would strain the BL motor.
I like the fact that the Revo tranny sits lower and uses stock center shafts and slipper assembly. Creating a motor mount and finding a good spot for the batteries would be a bit of a challenge, but I don't want to start it unless I know if the tranny can even be used.
I've seen someone who has used the stock tranny with a BL motor before, but they used a larger spur and had to cut the chassis to allow for the larger diameter. I really don't want to do that.
