Something isn't the same. There has to be something you're overlooking.
What is your timing advance set to? How much heavier is your car, that could be HUGE.
Go back to the 48/16 gearing as that is the same as his. However are you guys running the exact same car? 1/8 cars often have either 3.3 gearing internal or 4.3. If you guys have one of each your gearing is NOT EVEN CLOSE!
