Thunderbruiser
Thunderbruiser's Avatar
09.28.2009, 03:30 PM
hmm never thought of that..I'll check the tekin g20 is rated for 20 cells max and no motor limit the novak is rated no motor limit 4-10 cell use I am only runnning 2 cells I'll see if it's the springs cause the brushes are still long
thanks for your info guys gonna go check it out right now
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
J57ltr
09.28.2009, 03:57 PM
If you are geared to the moon you will burn up brushes and the springs will weaken to the point they break. I used to run 8 turn single motor and would go through a set of brushes in about 2 battery packs (6 cell NiMh). Since you are using Lipo your burst currents will be a lot higher and you are probably eating brushes and overheating the springs causing them to sag which reduces the pressure on the brush, not to mention heating of the plastic endbell.
Jeff
Thunderbruiser
09.28.2009, 04:11 PM
geared 17/87 with 13x2 temped 185 after a full pack but within 7 minutes only temped like 140 the other motor I have hasn't even been ran yet. still fixing my leads right now gonna try an old titan eventhough it's a 14v motor it should spin if the esc work right?
garage:
J57ltr
09.28.2009, 04:21 PM
yes it will run, if its not worn out.
87/17=5.12:1 what is the gear ratio in the diffs?
Jeff
