taboo question....
whitrzac
Can't catch this...
whitrzac's Avatar
taboo question.... - 10.04.2009, 10:00 PM
I need a high amp BRUSHED, HV esc for a duel motor project....
it needs
high amp(higher than the evx2)
prograbale to a pistol radio
4s + capable, no cutoff needed
waterproof??
under $100
10.04.2009, 10:03 PM
Brushed? MMM...
whitrzac
Can't catch this...
whitrzac's Avatar
10.04.2009, 10:06 PM
Brushed? MMM...
yes brushed...
nitrostarter
nitrostarter's Avatar
10.04.2009, 10:07 PM
MMM can be run in brushed settings quite well.
N. Rustler conversion
10.04.2009, 10:11 PM
Used MMM can be had for 100 bucks... Or try a MM. I have had good success with the MM on 2 potent brushed motors.
Neither will be waterproof and the MM will need an external bec to run 4s. So it looks like the MMM is the winner. Plus you have a really good brushless esc too.
whitrzac
Can't catch this...
whitrzac's Avatar
MMM is a little too expensive right now...
whitrzac
Can't catch this...
whitrzac's Avatar
10.04.2009, 10:12 PM
I have an RX8 in my box that I forgot about its going to be a PIA to watterproof it though
any sugestions on a watterproof esc???
I'll let the cat-outa-thebag now, its a duel dewalt motor (mabey^3) muggy
10.04.2009, 10:34 PM
I see, cause regular single BL motor muggies are way too light, right?
whitrzac
Can't catch this...
whitrzac's Avatar
10.04.2009, 10:39 PM
no, I want somthing that I can run in the snow/water and brushed just cheaper....
$30 for a motor...
nitrostarter
10.04.2009, 10:51 PM
I have a Astroflight 212D brushed ESC. Not sure how it can be programmed but if you have mechanical brakes, it would definitely work.
