bruce750i
bruce750i's Avatar
12.19.2009, 02:42 PM
It looks great U Spy! Nice work with the dremel.
Urgeoner
Urgeoner's Avatar
12.20.2009, 01:50 AM
So has anyone had a chance to actually run this motor? I know it's 45k max, but is it fast enough?
bruce750i
bruce750i's Avatar
12.20.2009, 01:27 PM
I have here is some Video of it in my Project: Savage X-17
It all depends on your gearing. This motor should be able to pull some crazy (1/8 scale) gear ratios.
Assuming the esc and lipos can handle it.
Last edited by coolhandcountry; 12.21.2009 at 09:40 AM. Reason: Hit a return so everbody won't have to scroll over.
12.21.2009, 12:50 AM
Is it fast enough? Most here run about 35-40k rpms on their MT setups. I have run motors closer to 50k for lighter vehicles, 10th scale and 1/8 buggies, but those motors were smaller/lighter...
Holding it in my hand I have a feeling it will easily eclipse the power my neu 1521 1y on 6s puts down. That is a 1600kv motor on 6s, so not beating 40k rpms... The 1717 will have more torque than the 1521, but may spool up slightly slower. I have a feeling it will really weed out the crap lipos though, hope the 40c zippies can keep up.
I need to get suspension back under my lst and give this bad boy a try, My 2nd tdr mount came in, and this one has the m4 sized front plate so I can run my 1717 without the rcm thread adapter plate. I will get it together at work tomorrow and post some pics of the motor correctly mounted with the new tdr plate and the 25/63 gearing.
Hope to have the battery tray made up and the truck running by christmas!
Urgeoner
Urgeoner's Avatar
12.20.2009, 02:54 PM
That looks really cool Bruce! I like the center diff especially!
Unsullied_Spy
Unsullied_Spy's Avatar
12.26.2009, 06:57 PM
I got my bearing in from Boca and now it seems I borked a CD bearing, but I ran it anyway. Pretty sure the can is too big to allow for my 14T pinion, so I slid on a 16T just so I could run it (geared for 60 MPH before ballooning). Accelerated my ~14 pound Muggy to top speed as fast as the tires would allow and in the 3 minutes that the pinion stayed on the shaft it never got even noticeably warm (running without a body). Seems like the perfect motor for my Muggy, but I'll have to wait until Summer to see if I need to mod it to take a bigger spur because there's no way I can gear it down to 45 with those tires and the stock spur.
I got some video, it's kinda crappy but it works. I have no internet at home right now, but hopefully I can netstumble upon some sucker who thinks WEP is "good enough" and get the video up.
Urgeoner
Urgeoner's Avatar
12.29.2009, 11:29 PM
Any word when I could send my motor back and get the 5mm shaft version? It's still in the box and I never had power run through it yet...
Unsullied_Spy
12.31.2009, 01:14 AM
riverat1540
riverat1540's Avatar
12.31.2009, 08:22 AM
the snow on the ground really wont let it perform it seems, i think when i have the money ill put the 1520 in mine as i want more gearing options but ill have to buy a new chassis plate as mine still resembles a taco. nice vid looks cold out there. really makes me want to get mine out again.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
Unsullied_Spy
12.31.2009, 03:14 PM
Yeah the snow wouldn't let it hook up very well but the power is insane. It was around 0 that night, but I really wanted to run it!
coolhandcountry
coolhandcountry's Avatar
12.31.2009, 04:26 PM
If it has any power like my 2250 had.
It is a awesome and fun motor.
Peace!
Country
Help support the
Rc-Monster
Buy here
01.01.2010, 01:19 AM
Too vague.
What truck and motor do you have exactly?
What speed are you aiming for roughly?
How much money do you have to spend on lipos & charging equipment?
How much experience of BL and high end r/cs do you have?
Answer that little lot then we'll be able to make some proper recommendations...
coolhandcountry
01.01.2010, 11:33 AM
What would people think about 1717 on 4s lip?
Peace!
Country
Help support the
Rc-Monster
Buy here
sikeston34m
sikeston34m's Avatar
01.01.2010, 12:09 PM
IMO, alot of it really comes down to available gearing options.
Neil, you are right about unleashing it's full potential, But........
Even on 4S, such a well built motor can really perform.
Example:
I just picked up another Heli motor. I have an obsession with outrunner type motors, thus the reason for the avatar.
This one is HUGE. 43mm X 72mm. It is a 8 pole outrunner that yields 1100kv.
It's stator is 35mm in dia. X 38mm Long. Very strong magnets.
The advertised rating is 1600 watts continuous and 6S.
The Thing is a Torque Monster.
I've only ran it once so far on 4S, but in an E Revo geared 25/36 using Mod 1 gears, It is very impressive.
No Cogging and it will backflip. LOL It runs really cool too.
1st run was cut short when the Motor Pinion came loose. This time it got some Blue Lock Tight.
Back on Topic, the 1717 looks to be VERY well built. I can see one of those in my future.
I see alot of talk about Maximum RPM's, but you gotta realize just how much torque the lower kv motors are capable of.
How high it winds becomes less of a performance factor, the larger the motors get.
01.01.2010, 11:47 AM
1580kv on 4s will be rather slow, needs a bit more voltage to unleash its potential I would say.
