RuthlessLST
03.09.2010, 04:36 PM
Where and when can I order a 1717 with the 5mm shaft?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
03.09.2010, 05:06 PM
Originally Posted by ruthlesslst View Post
where and when can i order a 1717 with the 5mm shaft?
+1 !
Pdelcast
Pdelcast's Avatar
03.09.2010, 05:08 PM
We should have 1717 5mm shaft motors in early April.
Thanx!
Patrick del Castillo
President, Principle Engineer
V0RT3X
Muggy love
V0RT3X's Avatar
03.06.2010, 10:53 AM
Offshore electrics has a note that they're expecting a new batch on April 10. Hope they come with a 5mm shaft.
Urgeoner
Urgeoner's Avatar
03.10.2010, 06:58 PM
Okay Patrick, I sure hope this holds true!
nitrostarter
nitrostarter's Avatar
03.10.2010, 08:50 PM
Some charts or graphs are always nice
N. Rustler conversion
V0RT3X
Muggy love
V0RT3X's Avatar
03.11.2010, 10:27 AM
What will happen to the ones with the 6mm shaft at RCM store?
Urgeoner
Urgeoner's Avatar
03.11.2010, 06:29 PM
Hey Patrick. I sent you a pm about the 5mm one. I also question the power difference between 1717 1520.
Nick
COOKIES!
Nick's Avatar
03.12.2010, 09:05 AM
I know the diameter is bigger on the 1717 than the 1515s but are the mounting holes the same?
~ Nick.
Thomas Porfert
Thomas Porfert's Avatar
03.19.2010, 06:09 PM
Originally Posted by V0RT3X View Post
And how long is the shaft on the 1520/1717? Around 20mm? But I can still cut it short if needed.
They are 18-21mm, 20mm on average.
Same size bolt pattern, ~ 25.4mm center hole to center hole; 3mm screws on both.
That means you could fit a 1717 motor to the mini E-Revo tenbol mount. A motor that weighs more than the car? I don't see a problem with that! :)
Thomas Porfert
Castle Tech Support
nitrostarter
03.19.2010, 06:39 PM
Thomas Porfert
Castle Tech Support
Would be cool, but you couldn't gear it high enough to take advantage of the torque it makes. You you need an output multiplier...
V0RT3X
Muggy love
V0RT3X's Avatar
03.20.2010, 04:09 AM
Thomas Porfert
Castle Tech Support
Aren't the screws on the 1717 4mm?
NickRummy
NickRummy's Avatar
03.20.2010, 07:47 AM
They are 4mm on mine. Thought they were 3mm too like listed in the specs but they arent. Atl least the older ones arent.
Thomas Porfert
03.20.2010, 12:54 PM
I'll have to double check a production motor on Monday. I was measuring a prototype motor in engineering, so it may have changed before it hit production. I was thinking 3mm seemed a bit small for that size motor, but I'll verify on Monday; sorry for the confusion.
Thomas Porfert
Castle Tech Support
03.13.2010, 07:09 PM
25mm hole spacing & M4 holes/screws.
Unless Im trippin' again.
