Beanie
10.07.2009, 12:06 PM
Sorry, another question, the Hyperion lipo apparently can be charged at '5C'
What does this mean?
I'm going to get a Imax B6AC charger/balancer, are they OK?
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
10.07.2009, 02:13 PM
Sounds like a great setup to me, should work just fine, just fine at whooping nitros that is.
5C means you can charge it at 5x the capacity in Ah... so 6.5Ah (6500mah) x 5 = 32 amps. However, no charger yet can do this, the Hyperion 720i can charge that pack at 15 amps though, which is 2.3C, less than half of 5C.
Have you considered going with a 6s lipo setup and a 1500kv. Tekin truggy motor? You would need a 6s/4200mah pack, which I personally use.
Beanie
10.07.2009, 02:25 PM
Thanks for the advice, gratefully received!
So how quick would the 6500mah Hyperion pack charge using their 720i charger at 15 amps? Would this be detremental to the lipo at all?
Tekin and 6S; I was wondering if 4S might be more than enough for me right now and the MMM kit seems to have a fairly good following....why would you recommend the Tekin and the 6S over say the MMM/2200kv/4S 6500mah set-up? What's the benefits do you think?
Cheers
