what do now
what do now's Avatar
10.07.2009, 02:27 PM
Hot bodies drive cups are what I used, but finding them ( or any 8mm bore versions for that matter ) is somewhat tricky. I would hit up ebay to start with, search for 'hot bodies'... but specify in the toys & games section, otherwise... well, you can only imagine the results you will get. I'll have a look too when I get home- the work PC doesnt like alot of sites that use flash, and no way to update it withot being an Admin.
As for diff fluid- 7k front & 5k rear is a good starting point, or 5k front & 3k rear maybe if you prefer a bit more diff-action.
Thanks, I did have a look around for 8mm bore drive cup but nothing. Plenty of drive cups but when your not sure what is 8mm and whats not it is like sticking a pin in them and there no chance any place will put a description with the them
Diff fluid, might go for the 7/5k so.
