bdebde
That's All Folks!
bdebde's Avatar
10.09.2009, 02:21 AM
So, The chassis had these 2 extra holes in the ESC area, but no screws or anything called out to go in them.
Hmmm, looks like one of these will fit... sure enough!
I had to order a whole bag of 50 screws just to get the 2 that I needed. I also had to cut the switch mount off as it stuck out past the side of the chassis.
ID:	7820   Click image for larger version
bdebde
That's All Folks!
bdebde's Avatar
10.09.2009, 02:57 AM
All finished except for painting the body and the missing body post (on it's way from HB). Body post should be here tomorrow, and I will be painting the body tomorrow as well (hopefully).
Ended up trying an Orion Vortex VDS1409 servo; 14kg (195oz) @ .09sec. Local hobby shop gave me a great deal on it so I will give it a try. Weight is about 7.6 lbs... not too bad. Hb makes lots of light weight parts, so I could drop the weight some if I need to. The motor/battery side is less than 2oz. heavier than the other side. If I was running mech. brakes, it would probably be perfectly balanced. I will start with gearing at 1:1 rollout; about 33mph. This may be plenty fast enough for the small indoor track I will be running on. Also, since the Lehner motors are rated under load for kv values, I may be a bit faster.
ID:	7822   Click image for larger version
ID:	7823   Click image for larger version
