Go Back   RC-Monster Forums > Support Forums > Team Tekin
hubbaman
hubbaman's Avatar
10.13.2009, 04:18 PM
Originally Posted by TekinTeamMgr View Post
I'd like to know what setup you're running and having rotor issues. I'd like gearing, car, battery used,etc.
Well for me its a Tekno rc v3 x2-crt conversion running standard spur,12 tooth pinion,tekin Rx8/T8 2000kv truggy motor,hyperion 5s/6500mah G3 lipo,firstly, used direct drive,v2 rotor broke,2nd time used mechanical brakes, with esc drag brakes and normal brakes turned off,replacement v2 rotor broke even quicker,third time i am going to try the tekno clutch,with mechanical brakes,on a 13 tooth clutchbell,hopefully the rotor will last longer then 4 minutes,but will let you all know.
