jas21373
10.17.2009, 08:34 AM
muggy diff cases are the same as Lst diffs,muggys have 43/11 crown and pinion ,you may want to try Sportwerks Mayhem Turmoil diffs they also are a direct fit and have 43/13 crown and pinion.
bdebde
That's All Folks!
bdebde's Avatar
10.17.2009, 01:30 PM
Are the muggy diffs a straight swap bdebde?
Yes muggy diffs are a drop in to the lst2 cases, Sportwerks are as well; and you can use Mayhem ST TiNi gears for bulletproof muggy ratio. Running that in my muggy.
10.18.2009, 08:43 PM
Motor above the diff works well. CD mounted to custom bottom plate, fits right up in the tranny hole, slight filing may be needed around the outdrive cups. Gearing would be quite limited with stock F/R diffs, which is why I will be using Muggy diff gears to give a little more choices. I will also be using a 48 - 50t spur (12/46 shown) to give further gearing options, although 11/46 fits current configuration.
I'm doing the same thing with my LST. One regular LST and one LST XXL driveshaft seem to give the right length for a center diff in an LST. It almost falls together!!
jzemaxx
10.20.2009, 11:48 AM
Coolest setup I've seen so far....
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.16.2009, 07:59 PM
I find out when I cross that bridge, I hope to start on that after I make a few much needed repairs on a few other trucks. Maybe in a couple weeks ?
redshift
RC-Monster Square Tube
redshift's Avatar
10.16.2009, 11:56 PM
^That schitt is CLEAN bdebde^
Center diff/center spur FTW
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.17.2009, 12:55 PM
Looks interesting, I feel a little inspiration.
bdebde
That's All Folks!
bdebde's Avatar
10.18.2009, 06:50 PM
You will need the 45t ring gear and the 11t pinion to match it, and they will fit right in the LST2 cases
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.21.2009, 11:32 AM
Single servo on the LST is easy and works very well.
JAILBIRD
10.21.2009, 05:34 PM
I want to do this but one question, why no servo saver?
jzemaxx
10.21.2009, 03:32 PM
I run a single servo as well....just like above with a JR8711
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.21.2009, 05:56 PM
This is one of the baddest servo on the market, 541oz Torque at 7.4volts, All Titanium gears. I've broken several aluminum servo horns and the LST2 steel drag links with this Robot servo. I have several and they are worth the $$ for sure.
http://servocity.com/html/hsr-5990tg_servo.html
JAILBIRD
10.21.2009, 06:49 PM
Kick ass, thanks Bondonutz! I definatly need to order one of those soon, my JRs are on their way out.
-JB
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.21.2009, 07:02 PM
-JB
Shop around, I've seen them as cheap as $109.99
