naynay12
10.15.2009, 04:06 AM
Ok i have bought everything apart from the motor mount.I have a savage x ss,and have bought a 2200kv flux tork motor.Which mount will i need?
http://204.186.93.64/MotorMounts.html from kershaw design?
The savage 700 motor mount or
HPI Savage X/XL 700 Motor Mount
scarletboa
scarletboa's Avatar
10.16.2009, 08:11 PM
if the chassis plates are meant for a savage x, get the 550 x mount. if your chassis plates are meant for the pre-x savages, get the 550 mount.
edit: if you have aftermarket plates, if they are symmetrical on both sides, get the pre-x mount. if each side is a little different, get the x mount
naynay12
10.24.2009, 06:00 AM
Ok i have recieved most parts apart from the motor and ezrun1 50a esc,and motor mount.Pics will follow once complete.
Does the ezrun bec work fine ?Will I need an external bec to power my steering servoi?
Will i need to break in the battery as such,(turning 5s 5000mah)like driving slow etc?
Can i connect the failsafe/will i need it?
I have a turnigy 5s 5000mah lipo,can i charge at 10a,or do i have to charge at 1c (5A) ?
I also need help with the charger/how to charge a battery.I have the charger and power supply in my pics.My question is how do i connect the power supply to the charger?
The charger has a positive and negative female 4mm bullet conector which the the battery connects to.It also has two of the plier connector things(positve and negative),which i think connect to the powersupply,its just that need to modify the connectors somehow to fit right?Also how would i go about charging with a car?
ID:	7887   Click image for larger version
