Thomas Porfert
Thomas Porfert's Avatar
10.16.2009, 10:37 AM
Definitely check your throttle trim and make sure it's at 0. The only reason I was think it was something more serious is because the light doesn't change when he hits the throttle. Which would mean the radio isn't sending out a good signal on the throttle channel. We see it from time to time on some radios where just one channel conks out.
Sometimes trying a different radio system is the easiest way to test. Just toss a known good radio in place of the questionable one and see what happens. If it works, then the first radio is the problem. If it still doesn't work, you've got an ESC problem. Simple, quick and definitive.
Thomas Porfert
Castle Tech Support
alport
10.16.2009, 10:49 AM
My throttle trim is at 0. I checked this first. The radio works properly with another esc. But I'll try another radio on this weekend. I'll check the voltage of the receiver wire and let you know.
Pdelcast
Pdelcast's Avatar
10.16.2009, 01:29 PM
You can always test the radio by using a receiver battery and plugging a servo into the throttle channel on the receiver. If the servo moves when you move the throttle trigger then the radio is OK and the problem is either ESC or ESC calibration. If the servo doesn't move, then the problem is with TX programming or the receiver channel.
Thanx!
Patrick del Castillo
President, Principle Engineer
no to jack your thread but had to comment after reading this
riverat1540
riverat1540's Avatar
no to jack your thread but had to comment after reading this - 10.16.2009, 01:48 PM
I talked to someone yesterday after getting my replacement, another is on the way which is great. the problem was when i plugged everything in to the reciever it would not arm, so i unplugged my coolong fan and still nothing then i unplugged my steering servos and it armed right up, then i pluggeg in the steering servos it lost power, thinking i had a problem with my servos i unplugged the monster and plugged in my reciever battery (6v) and everything worked fine, then i unplugged the battery and plugged the monster back in and same problem. i called and explained my problem and another replacement is on its way. afterwards i tried it with only one servo and it powered up but the voltage was weak as the servos turned very slowly with almost no torque. what would cause the bec to output less than ample power to the reciever? just never heard or anyone else having this problem so thought i would share it and im always up for learning something about my components. i am happy to report tech support was great as usual and i cant wait to get the new one hooked up before the snow comes.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
alport
10.17.2009, 06:46 PM
Ok. I tried something that you said. I'm hundred percent sure my radio working correct and I measured the voltage on the receiver wire 5.82V so the the bec is OK too. After trying differnt solutions my problem changed a little. İf I first open the esc (not calibrating) it launchs with its classical ringing and blinking three leds and then only the red led begin to blink and the motor don't works on throttle or brake.This means that the esc need to be calibrated. If I try to calibrate the esc and launch it on full throttle it opens again with its classical ringing and blinking three leds and then there is only solid yellow. After the solid yellow led if I let the trigger to neutral position the motor moves forward.
I'm sure my radio is working properly and my throttle subtrim is at neutral. I need your help!
