Pdelcast
Pdelcast's Avatar
10.19.2009, 12:39 PM
Originally Posted by SpEEdyBL View Post
Very true, but the 1900 i am refering to is effectively a 1512 1.5Y with twice as much resistance.
You could make the resistance 50 times as much -- still wouldn't have any real effect on current draw.
You have to realize these motors will pull whatever current they need to produce the torque you ask of them.
A 1512/1.5Y has about 6.5 milliohms of resistance. With a 20 volt battery, the stall current is about 3100 amps.
A 1512/1Y (like the Castle 2650 motor) has about 4.5 milliohms of resistance. With a 20 volt battery, the stall current is about 4400 amps.
So you see, resistance doesn't matter ONE BIT. It's about torque generation -- which is gearing, tires, terrain, vehicle weight, etc.
The motor will draw whatever current it needs to generate the torque that is asked of it. A 1512/1.5Y when incorrectly geared can easily draw over 1000 amps.
All of these types of motors don't have enough resistance to have any real effect on current draw.
Patrick del Castillo
President, Principle Engineer
