Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
PBO
RC-Unobtainium
PBO's Avatar
10.19.2009, 11:30 PM
I've posted this elsewhere in reference to an excellent mini revo custom build, it may be of some benefit? Apologies for being lazy....
"I see there are 4 basic elements to an open wheel design...1st is the splitter, 2nd is the body, 3 is the rear wing & 4 is wheels
You can adjust everything except the wheels fairly easily & this is the splitter function...
but in your case I think something more exaggerated in terms of length & perhaps even reducing the high pressure area by smoothing the splitter to body area - which increases the downforce...& then if you need to, you can reduce this effect by reducing the size of the splitter. I hope that makes sense?"
In most cases, the splitter can be mounted directly to the chassis via a simple CF or alum plate using the existing diff screws
I also think a 1/8 rear wing might be too aggressive & reducing the near vertical elements will work well to decrease drag but maintain sufficient downforce. Combined with the enlarged vertical end plates, it should work perfectly with some fine tuning
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
