JThiessen
JThiessen's Avatar
10.27.2009, 09:24 AM
Originally Posted by ilpufxit View Post
Does anyone know the latest on Savage upgrade diffs? Mine just started clicking and I'm waiting for the new ones. I tried to underpower my truck with a 1512 2.5d on 5s but I guess it was still too much.
What do you mean by the latest? They have been out for a while now. I've got a set that are being installed now, Freezebyte has some installed....what did you want to know? They look beefy, the gear ratio is lower - so you need to replace both front and rear.
And just an FYI, from my experience, be prepared to by some extra diff cups...those crummy soft phillips screws dont want to come out without stripping.
Freezebyte
10.27.2009, 01:07 PM
Haven't had issue with phillips stripping with high quality tools, but on my stock diffs set there was so much torque at one point it actually broke two of the screws inside the diff cup.
Bulks?
ilpufxit
ilpufxit's Avatar
Bulks? - 10.27.2009, 09:49 PM
I thought I heard that tougher bulkheads are necessary to prevent flex and there was a complete set coming out from HPI. Maybe I was dreaming....?
JThiessen
JThiessen's Avatar
10.27.2009, 10:13 PM
Might be....dunno. The flux bulks are a composite, as compared to the plastic on the X and SS, but I have no idea if they are stiffer or not - that's why I went with the FLM's.
Freezebyte
10.28.2009, 01:45 AM
Eh? I've had no issues with the bulkheads.
JThiessen
JThiessen's Avatar
10.28.2009, 08:43 AM
Well, you didn't actually have any problems with your diff's either!
Any plastic bulkhead, and some aluminum ones, will flex. If that flex occurs under power, one could potentially damage the gears. The design of the savage bulkhead itself is quite rigid, so IMHO, flex is probably low on the potential list of problems.
Freezebyte
10.28.2009, 10:13 PM
