Go Back   RC-Monster Forums > Support Forums > Team Tekin
10.27.2009, 09:31 PM
There we go, no more white square. That white square video was interesting though, I was engrossed for about 20 minutes. Just kidding with you Tekin
Originally Posted by ticklechicken View Post
I currently have my Tekin hardwired. I bought some 6.5mm bullets to add, but I'm a little confused on where to add them. I want to add the bullets in the middle of the wires, but then the three bullets will hit each other while driving. What are others doing about this? I don't think heat shrink is durable enough to survive that long.
I want to use those bullets so I can swap motors with my MMM combo in my Revo.
Like Bondo said, you can double up on the heatshrink, or get shrink with a 2:1 or even 3:1 shrink ratio and get a larger size than you need. When it shrinks, the walls also get thicker which provides more insulation. BUt I really don't think you need to worry, I've used single layer regular shrink in every setup and it's fine. It might help to zip-tie the wires to something solid to keep them from bouncing around though. Not only does this help prevent wear, it also makes less stress on the solder joints and wires.
