Where to get 10 cells battery packs?
RC Fan 4 Life
Where to get 10 cells battery packs? - 01.28.2006, 12:37 AM
Just wondering where would you buy 10 cell packs for a e-maxx? Would they even fit in with gorilla straps.
squeeforever
squeeforever's Avatar
01.28.2006, 01:08 AM
yea, they would fit but you would have to make them with 8 flat and 2 ontop
Serum
Serum's Avatar
01.28.2006, 02:05 AM
Mike can make you a few packs of the IB3800's.
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
01.28.2006, 09:39 AM
anything is possible!
  Send a message via AIM to nbcaznmaster
RC Fan 4 Life
01.28.2006, 11:40 AM
What do i need to put them togeather myself? I know i need the batteries. jig to hold them, wire, connectors and battery bars. I've tired to put them togeather before but solder did not want to stick to them so i'm guessing they weld them of some sort?
squeeforever
01.28.2006, 12:03 PM
nope, just solder. you have to put a little on both the bar and the battery or it wont stick.
skellyo
skellyo's Avatar
01.28.2006, 12:59 PM
You also have to make sure you use a high enough wattage soldering iron. 60-100W should do fine
RC Fan 4 Life
01.28.2006, 02:30 PM
My soldering iron is cheap so it's probably not hot anough. Is there any good how to's on how to make a good battery pack?
skellyo
skellyo's Avatar
01.28.2006, 03:58 PM
This one would probably do what you need:
http://www.partsexpress.com/pe/showd...number=372-204
RC Fan 4 Life
01.28.2006, 04:52 PM
My soldering iron is 23W lol
markland556
markland556's Avatar
01.28.2006, 08:57 PM
just sand the ends of the batteries and the bars slightly, then use flux.
  Send a message via AIM to markland556
RC Fan 4 Life
01.28.2006, 09:18 PM
What's the flux do?
markland556
01.28.2006, 09:45 PM
allows solder to melt at lower temperatures and makes it stick to the surfaces. Its very hard and stupid to solder without flux (resin)
RC Fan 4 Life
01.28.2006, 09:52 PM
Where can i buy flux? Do you mix it with the solder or what?
btw how do you charge a 10 cell battery pack? My chargers max is 8 cells
squeeforever
01.28.2006, 11:02 PM
well i guess you wont be able to charge one.... gotta get a charger to charge them or reduce your cell count... if you get another i would recommend the astroflight 112dx.
