Freezebyte
11.09.2009, 11:49 PM
Here's a 3S Turnigy 20C 5000mah discharge graph. It's half of a 6S setup being ran in a Savage Flux.
The Max was 112 amp draw. If you look on the graph at the 112 amp spike, it's holding 11.1 volts. That's 3.7 volts per cell.
That's more than 20C.
Can you elaborate a bit more on what i'm seeing on this graph? its kinda fuzzy and hard to read the details.
sikeston34m
sikeston34m's Avatar
11.09.2009, 11:57 PM
The Blue Line is the Voltage. See at the top, the pack voltage at the beginning is about 12.5 volts. Almost fully charged.
The Red Line is Amp Draw. Each Red Line Spike is a stab at the throttle.
The Blue Line is pack volts.
The numbers on the right side are amps. The numbers on the left of the graph are for volts.
Pick a Red Spike on the graph, then go to the right to see how many amps that spike peaked at. Then under that same spike, see how low the blue line goes, then go to the left for the voltage value.
For each amp spike, you can get an idea of how the pack held voltage under the load.
I hope this makes sense to ya.
