J57ltr
11.14.2009, 11:56 AM
So Joe, have you checked out your servo?
sikeston34m, Yes you and Joe's friend are the other 2 I was refering to. What was wrong with your servo?
Jeff
sikeston34m
sikeston34m's Avatar
11.14.2009, 12:02 PM
Jeff
I believe it was a factory defect. I took the servo apart and it's control board was burnt.
This tells me that I "over amped" the BEC inside the MM Pro, without damaging it.
I also believe the BEC has over amp protection.
As a servo's gears begin to wear, it draws more current. If a person is having problems like this, my advice would be to check your servo.
J57ltr
11.14.2009, 12:21 PM
So it was a new or pretty new servo in your case? I am wondering why adding a cap "fixed" Joe's problem.
Jeff
Pdelcast
Pdelcast's Avatar
11.14.2009, 12:33 PM
Jeff
WARNING: Long boring technical explanation follows:
We've seen the same thing on the bench since this problem was reported. Apparently, some of the JR servos draw peaks (short -term) of several (5-6) amps for a couple milliseconds when changing direction. (We have speculated that the drive transistors in the servo are shooting-through during direction changes, but haven't yet verified that.) It's just barely long enough of a surge to trip the BEC over-current protection in the MMPro, and it shuts off the BEC for about 50ms. Adding a big capacitor to a servo connector (like a stutter-stopper) supplies enough current during those big surges to keep the MMPro from tripping the over-current on the BEC.
We are bench testing a hardware change that will add a very slight delay to the over-current shutdown on the MMPro to compensate for the JR servos.
Note that we have only seen this behavior on two specific JR servos, and adding some capacitance to the BEC line seems to be a good fix for the issue.
Patrick
Patrick del Castillo
President, Principle Engineer
Last edited by Pdelcast; 11.14.2009 at 12:41 PM. Reason: terrible grammer! don't wanna trigger the grammer police!
J57ltr
11.14.2009, 12:47 PM
No such thing as a long boring technical explanation. Thanks for the info.
So could the same thing be happening on the hitec servo as well? What is the minimum amount of capacitance you would recommend?
Thanks
Jeff
