Gee
A Horse's Ass
Gee's Avatar
11.22.2009, 04:44 AM
Weird. With the static IP set on the webserver and the rest of the PCs still set to DHCP, I can remote desktop into the webserver from any other PC in the house, but cannot ping it from those same PCs. But, I can ping those PCs from the webserver. They are all hooked to the same router. I can ping the router from each PC and the webserver. I even added the ping program to the firewall exceptions.
THat could be the DNS or WINS ip setting.
It's been a while but if the workstations have a LMHOST lookup box checked. I think you'll want that unchecked unless you have one on the workstations.
Freezebyte
11.22.2009, 04:50 AM
You can just statically set the IP address in Windows to something in the subnet range and the Linksys will know that one is not available, even with DHCP turned on. I've done it plenty of times in the past with no issues, most home routers are smart enough to figure out what IP addresses are being used and not available
