Is it possible to pre order the 1s esc or do i have to have my friends hobby shop pre order one ?. He is a authorized castle dealer in tampa fl .
Should be able to do either. However, you (and your dealer) will have to wait until we have all the part numbers in the system -- you can't order until that is done.
Thanx!
Patrick del Castillo
President, Principle Engineer
Thanx!
Is one better to do that the other ?. There were alot of the MM pro's at minnreg this weekend. This race is a club level race put on by mike boylan . The oval guys were using them the most from what i saw .
Thanx!
Will it be available for purchase thru your web site Patrick, or do I need special connections?
Thanx!
Hi PATRICK
Any idea when that will be & the approximate price ?.
Here you go gents, I present to you the Mamba Max Pro 1s Special Edition speed control. Right now they are not available, we are only taking preorders at this time. The release date is set for the first week of January. Because this is a test run to see if we want to keep this as a normal product, it has not been released to distribution yet. If they catch on as we hope, they will become a permanent product. You can find the details on our website, the price is set at $149.99 which is the full retail.
Please remember that is is the 1s version, so it will not have an onboard BEC. Also this controller will have solder posts instead of wires and will not have a fan or a switch.
Those of you that do not need a 1s version, it is recommend to purchase the normal Mamba Max Pro through the normal distribution channels (IE Mike); it will be cheaper because of retail and MAP pricing and we would rather see you purchase it through a reseller.
Let us know if you have any questions fellas!
Thomas Porfert
Castle Tech Support
I know some people are moding the mm pro to run on 1s . What are the advantages or dis advantages of buying the 1s esc versus modifing a mm pro to run on 1s ?. Thank's
