Semi Pro
Semi Pro's Avatar
12.03.2009, 04:13 PM
cool............did you chew it open?
brushlessboy16
brushlessboy16's Avatar
12.03.2009, 04:20 PM
No. I used a sharp wood chisel, a few flat blade screw drivers and a lot of patience... th entire back side of the unit is filled with adhesive silicone... it took alot to get the thing off..
I think my method of charging it was better.. Read through the amb manual and found out that the charging rack outputs 3v dc current.. so i found the only thing i had with 3v (2 alkaline cells, my handy-dandy game boy!) hooked some aligator clips to the battery terminals and onto the posts of the transponder.. its charging as we speak...
